AutoCAD Electrical Forum
Insert New Viewport In Paper Space
3 REPLIES 3
knight1fox3
15940 Views, 3 Replies
As the subject says, I'm a bit new to ACAD Electrical 2013 (coming from 2009), and I've done a bit of searching on my own.  But I can't seem to find which menu contains the action to add an active viewport within paper space (see screen shot below).  A number of tutorials indicate to use the "layout" tab but I do not have that menu nor can I activate it by right-clicking on the toolbar area.  Any assistance would be very much appreciated.  Thanks in advance.
3 REPLIES 3
sonny3g
in reply to: knight1fox3
Turn on your menu bar, then select View/Viewports/New Viewports... or one of the named viewports in the list.
Or, type vports at the command line.  Either way will pop up the Viewports dialog box.
Scott G. Sawdy
scott.sawdy@bluecoyotecad.com
testsubject
if you look in the lower left hand part of the AutoCAD window you will see that you already are in the layout tab (Layout1).
If you type VPORTS at the command prompt this will bring up the Viewports Dialog Box. From there you can add viewports to the layout.
You can make the viewport as large as the titleblock or have multiple viewports to show different areas from modelspace.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
knight1fox3
Thanks for the suggestions.  I thought perhaps they did away with the menu bar in 2013 so I didn't even consider that option.  I knew of the command line but I always like to have a quick button/menu item to do tasks quicker as opposed to repetitive command typing.  With the menu bar displayed, all the old commands I was used to 2009 are now present.  Thanks!
”Boost
