AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Insert new ladder reference format issue
3 REPLIES 3
l1389738
601 Views, 3 Replies
I have set up my drawing format as follows: Format Referencing/Reference Numbers/Sheet and Numbers in Hexagon.
The issue i am having is that when I insert a new ladder into my drawing the the 1st rung does not display any reference information inside the hexagon. The following rungs display correctly. Any advice would be greatly appreciated.
3 REPLIES 3
jalger
in reply to: l1389738
Hi I1389738,
Can you post a sample drawing and project (with only the one sample drawing with the problem) for us to take a look at?
James Alger
James Alger
(I'm on several hundred posts as "algerj")
Work:
Dell Precision 5530 (Xeon E 2176M)
1tb SSD, 64GB RAM
Nvidia Quadro P2000, Win10
dougmcalexander
Be sure you add %S to the Component tagging, wire tagging, and the cross-reference format in Drawing Settings.  You will also need to use the PLC database File Editor to add %S to the PLC tagging format.  The default is PLC%N.  It will need to read PLC%S%N or your PLC tags will look something like PLC00 instead of PLC100.
James addressed the other.  We will need to take a look at your drawings to see what might be wrong.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
dougmcalexander
Glad to help.
Doug McAlexander
”Boost
