I have lost a whole day to this. I even reinstalled but it is still doing it.
Please help ...screen shot included:
We will need a bit more information from you if we are to be able to help.
What version of ACADE
What style of ladder do you want, Horizontal/Vertical, With Bus or Without, Single or Three phase, With or Without Rungs.
Width Setting and Rung Spacing.
Length and 1st Reference if used.
Steps taken to get what the screenshot shows
Object Snap On or Off
Snap On or Off
Regards Brad
Icemanau (NNTP handle: Brad Coleman
AutoCAD Electrical User and IT Hardware Support
I finally got things straightened out, I had to uninstall and manually remove all associated acade folders
acade 2015
vertical
single phase
no rungs or bus
in the screen shot I started a new drawing inside the project. I put a 2x2 box in the upper left of my title block (to be deleted later) as a consistant starting place.
then just insrted a ladder as I have been doing for the last three days working on this project and I got what you see
this is what I expected to see:
One thing to watch out for is your project properties path for the schematic library symbols. This can affect your ladder reference number because when AutoCAD Electrical draws a ladder, it inserts a block (WD_MLRH or WD_MLRV) for the first reference number. If your drawing properties are for inches and your project is pointing at a metric library set, say IEC-60617, the reference number will look huge as it did in your first image.
Pat Murnen
