ACAD Electric 2014, when inserting or editing a child component, A lisp error occurs in the
Error Load Failed
"C:\\Users\Me\\Appdata\\Local\\Temp\\Insert_sec_trmDlgEvents,lsp"_,UNDO
I did a clean install and short of reformating my drive. anybody got any ideas?
I had a similar error occur for cable tags... Check your "Trusted Locations" under -> Tools / Options settings and verify if you have some paths missing. Some routines and scripts are run temporarily in these locations...
This may help...
If I create a new user in Windows 7, The "insert_sec_trmDlgEvents.lsp" works just fine. When another program cleans the temp file or any changes to the appdata temp directory, the "insert_sec_trmDlgEvents.lsp" fails to load.
