AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Insert connector from list
2 REPLIES 2
JMARSHALL1249
930 Views, 2 Replies
Could someone please let me know the format of the list for generating a connector from an .xls spreadsheet.
I have a complicated connector to generate, (a PLC ribbon connector) and think it would be easier to create the connector in excel, and import it straight into AE.
John.
2 REPLIES 2
in reply to: JMARSHALL1249
Hi!
As far as I know list for generating a connector has .xml format usually.
But! There is an interesting article about creating connector list in Excel. Maybe it could help you.
http://ketiv.com/support/tech-tips/unleash-the-spreadsheet
JMARSHALL1249
Thankyou for this.
From this, and a bit of googling from the source file, I have come up with the following, which may be useful for anyone considering using connector generation from a list, in the future.
All connectors .xls files require 27 fields which are as follows:-
PositionFieldPurposeColumn Type
1TYPE1CMP1: C = Connector/ S = SpliceText
2INST1Installation Code of CMP1Text
3LOC1Location Code of CMP1Text
4CMP1Component 1Text
5PIN1Connected pin on CMP1Text
6DESC1Description of CMP1Text
7CAT1Catalog number for CMP1Text
8MFG1Manufacturer of CAT1Text
9ASM1Assembly code for CMP1Text
10TYPE2CMP2: C = Connector/S = SpliceText
11INST2Installation Code of CMP2Text
12LOC2Location Code of CMP2Text
13CMP2Component 2Text
14PIN2Connected pin on CMP2Text
15DESC2Description of CMP2Text
16CAT2Catalog number of CMP2Text
17MFG2Manufacturer of CAT2Text
18ASM2Assembly code for CMP2Text
19WIRENOWire number (may be blank)Text
20WIRELAYWire layer nameText
21CBLINSTCable Installation CodeText
22CBLLOCCable Location CodeText
23CBLCable tag nameText
24CBLWCLRCable wire (conductor) colorText
25CBLCATCable catalog itemText
26CBLMFGCable catalog manufacturerText
27CBLASMCable assembly codeText
The example .xls file is attached for your info.
Thanks again.
Tags (1)
”Boost
