AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Insert Component Wiring List
1 REPLY 1
186 Views, 1 Reply
The insert component wiring list command (Schem wirenums to AutoCAD Electrical layout) does not reset the ATTREQ system variable. The command changes the variable to a value of "0" which will insert blocks with the defaults for the values of all attributes (not allowing the user to enter the values of the block's attributes during insertion.
Hyun Kim
Powell Electrical Mfg. Co.
1 REPLY 1
Hyun, You're absolutely right. I'll log this in the defect queue. Nate. "hkim" wrote in message news:5785611.1079728696042.JavaMail.jive@jiveforum2.autodesk.com... > The insert component wiring list command (Schem wirenums to AutoCAD Electrical layout) does not reset the ATTREQ system variable. The command changes the variable to a value of "0" which will insert blocks with the defaults for the values of all attributes (not allowing the user to enter the values of the block's attributes during insertion. > > Regards, > Hyun Kim > Powell Electrical Mfg. Co.
”Boost
