AutoCAD Electrical Forum
Insert Component Wiring List
1 REPLY 1
hkim
183 Views, 1 Reply
The insert component wiring list command (Schem wirenums to AutoCAD Electrical layout) does not reset the ATTREQ system variable. The command changes the variable to a value of "0" which will insert blocks with the defaults for the values of all attributes (not allowing the user to enter the values of the block's attributes during insertion.
Hyun Kim
Powell Electrical Mfg. Co.
1 REPLY 1
in reply to: hkim
Hyun, You're absolutely right. I'll log this in the defect queue. Nate. "hkim" wrote in message news:5785611.1079728696042.JavaMail.jive@jiveforum2.autodesk.com... > The insert component wiring list command (Schem wirenums to AutoCAD Electrical layout) does not reset the ATTREQ system variable. The command changes the variable to a value of "0" which will insert blocks with the defaults for the values of all attributes (not allowing the user to enter the values of the block's attributes during insertion. > > Regards, > Hyun Kim > Powell Electrical Mfg. Co.
”Boost
