AutoCAD Electrical General Discussion
Distinguished Contributor
10 Kudos
Post 1 of 3
Insert Component Configuration
262 Views, 2 Replies
11-20-2012 07:30 AM
Is it possible to configure the insert component menu .dat file so when you choose a component, it automatically inserts the symbol in a specific place rather than prompt the user where to insert it?
Yes,
In the Iconmenu wizard, add a COMMAND instead of a COMPONENT.
For the command string, use something like
(c:wd_insym2 "VMO13" (list 0.0 0.0) nil nil)
This will insert a vertical motor at 0,0, with no dialog box after insertion.
Have a look at the API help for more options for the wd_insym2 command...
Thanks very much, your'e a star :smileyvery-happy:
Works a treat.
141 Kudos
Post 2 of 3
Re: Insert Component Configuration
11-21-2012 12:59 AM in reply to: dbrblg
Yes,
Trond Hasse Lie
ECAD Consultant, CtrlAltEl
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
10 Kudos
Post 3 of 3
11-21-2012 01:18 AM in reply to: rhesusminus
Works a treat.
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
