Is it possible to configure the insert component menu .dat file so when you choose a component, it automatically inserts the symbol in a specific place rather than prompt the user where to insert it?
Solved by dbrblg. Go to Solution.
Solved by rhesusminus. Go to Solution.
Yes,
In the Iconmenu wizard, add a COMMAND instead of a COMPONENT.
For the command string, use something like
(c:wd_insym2 "VMO13" (list 0.0 0.0) nil nil)
This will insert a vertical motor at 0,0, with no dialog box after insertion.
Have a look at the API help for more options for the wd_insym2 command...
