AutoCAD Electrical Forum
Insert Component Configuration
2 REPLIES 2
dbrblg
466 Views, 2 Replies
Is it possible to configure the insert component menu .dat file so when you choose a component, it automatically inserts the symbol in a specific place rather than prompt the user where to insert it?
2 REPLIES 2
rhesusminus
in reply to: dbrblg
Yes,
In the Iconmenu wizard, add a COMMAND instead of a COMPONENT.
For the command string, use something like
(c:wd_insym2 "VMO13" (list 0.0 0.0) nil nil)
This will insert a vertical motor at 0,0, with no dialog box after insertion.
Have a look at the API help for more options for the wd_insym2 command...
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
dbrblg
in reply to: rhesusminus
Thanks very much, your'e a star Smiley Very Happy
Works a treat.
”Boost
