Do you want to force the label "Catalog" in the Insert/Edit Component dialog
to read some other text string? If you really want to do this, you can
probably make a small edit to one of your support file and see if it gives
you what you're looking for. You can try this... 1) back up file c:\program
files\autodesk\acade 200x\support\wds1ed.dcl, 2) Open the original file with
a generic text editor. Look for a block of lines in the file that looks
like this:
:edit_box{
label= /*dcl_s1ed_034*/"Catalog";
key="d_pn";fixed_width=false;
edit_limit=60;alignment=left;}
Carefully change the word "Catalog" to be what you want to see displayed in
the dialog. 3) Save the file. 4) test.
wrote in message news:5137327@discussion.autodesk.com...
Is it possible to change the titles in the insert/edit component catalog
data window??
I changed the title of my first column in the parts catalog to my companies
part no and would like the insert/edit catalog window to match
