AutoCAD Electrical General Discussion
Active Contributor
huyvu90
Message 1 of 3 (145 Views)
Insert attribute into a panel foot print
145 Views, 2 Replies
10-15-2012 02:54 PM
My panel footprint has only P_TAG1, RATING1 and RATING2 attribute.  How do I add DESC1, DESC2 and DESC3 attribute to my foot print so that my foot print display its descriptions?
Valued Contributor
lionSG
Message 2 of 3 (134 Views)
Re: Insert attribute into a panel foot print
10-15-2012 08:14 PM in reply to: huyvu90
Try to insert a nameplate.
It can either be referenced to an existing component footprint block or inserted as a stand-alone nameplate.
Go to Click Panel tab> Insert Component Footprints panel> Insert Footprints drop-down> Icon Menu
Select the desired nameplate and put it beside your footprint.
Thanks.
*Expert Elite*
Icemanau
Message 3 of 3 (128 Views)
10-15-2012 09:51 PM in reply to: huyvu90
Select the block and find the block name in the properties dialog.
Now do a search for that particular block and open it in ACADE.
Add the three attributes you want (DESC1, DESC2 & DESC3) and position them as you require.
Save the block.
Now go to your panel layout dwg and run the block swap/update command. Select the block on your panel layout and ACADE will remove the old version and insert the new version.
From here, you can do two things to get the description attributes filled.
Run the Child Location/Description Update command or  edit the block and re-associate it with it's schematic counterpart. This will force ACADE to update all the description attributes.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
Post to the Community
New Post
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
