I downloaded your drawing, inserted it into a project and ran a dxrawing
wide qire numbner update. The wire numbers are correctly assigned.
However, I do not have the drawing where the source arrows are. But I
suspect there is a problem with your project. Try this: Exit AcadE and
delete the project.mdb file in your user folder. Restart AcadE and it will
build a new database. This might fix the problem. Your database could be
corrupt. This can happen, especially if you have any network latency
issues.
wrote in message news:5795540@discussion.autodesk.com...
When doing a Project-Wide Update, wire numbers are incorrectly tagged for
wires connected to symbols that have internal jumpers. Please see attached
file.
