HI,
Please Any one can slove this issue.
When i insert a circuit i dont need CR coil & connected wires to CR, across M(contactor coil).so can you please tell me the procedure for that
I need this type as shown in below image.
Can't you just use Delete Component on the relay and then trim the unwanted wires?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Using circuit builder marker block drawing how to remove unwanted 25 or 45 degrees bend wire at the time of circuit insertation.i have removed horizontal & vertical wire by using this command (c:ace_cb_trim "XY01" nil).
I am writting below procedure by using marker block for your understanding.
How to remove bend wires in above image.
could you please tell me.
Thanks in Advance.
Now that I see what you are doing it makes more sense.
In the Circuit builder , every segment has to be identified with a marker block. So, if you place a marker block 6.2 XY01 on the two angled lines, they will be trimmed when you insert the circuit.
