AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Importing promise catalogs and projects
4 REPLIES 4
dammerel
668 Views, 4 Replies
Hi all
Has anyone tried importing promise catalogs and projects
into acade 2008 ? Andrew
4 REPLIES 4
penmouse26
in reply to: dammerel
Andrew,
You can check the conversion tools under the project pull down menu. We have manage to convert promise article database to default_cat mdb. It was done manually by a database expert. As for the drawings we have moved them into AutoCAD Electrical projects but can not pull report from them. This was done back in 2004 version. I'll check 2008 version tools this weekend .
Dave
dammerel
Dave
Thanks for the answee, I have a number of promise projects I would like the import into acade Andrew
The Promis-e Conversion tool will get you close. Promis-e manages terminal
strips differently so you may have to manually edit the terminal blocks and
update the Strip ID. The Strip ID may appear in the first block of a strip
in Promis-e (when they are close) but not in the other blocks (i.e. TB1:1,
TB1:2, etc.). You can use the Component Edit tool in AcadE to define the
strip ID for the blocks that do not have it defined after a conversion.
wrote in message news:5798934@discussion.autodesk.com...
Hi all
dougmcalexander
Another point about the Promis-e conversion with regard to MFG data:
Because of the way Promis-e's article database is managed, the
manufacturer's name isn't available to AcadE's conversion utility. The
Promis-e conversion utility will only be able to bring the part number, or
Catalog Number as it is called in AcadE, over during the conversion process.
But once the conversion completes, you can use the Spreadsheet
Export/Edit/Update feature to quickly and easily enter the MFG names into
the MFG attribute that is added to the Promis-e blocks. Just export the
Component data using Spreadsheet Export. Then edit with Excel, save, and
import with the Update from Spreadsheet feature.
"Doug McAlexander" wrote in message
news:5803304@discussion.autodesk.com...
Hi all
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
”Boost
