AutoCAD Electrical Forum
Importing into ACE_PLC.MDB
2 REPLIES 2
tconnolly
1232 Views, 2 Replies
I am needing to share a parametric PLC definition I created with a co-worker.  I can't find a way to export/import from within the PLC database file editor.  Using MS Access to export both the ..._Controller  and ..._Controller_Data tables from my ACE_PLC.MDB and then import them into my coworkers ACE_PLC.MDB file didn't work.  The tables are there when we open his ACE_PLC.MDB in Access, but when we start his copy of ACADE they aren't shown.
Am I missing something or is there a better way to do this?
Tags (1)
2 REPLIES 2
dougmcalexander
in reply to: tconnolly
Try the Migration Utility from the Project menu.  Select Content>PLC Database and set the source and destination databases.  There is more to it than just copying tables.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
董沁
”Boost
