If you only want to merge the PLC data from the previous version, expand the Content category and check PLC Database. Uncheck all other boxes. However if you have added any parts to the Lookup database I would recommend migrating the Catalog Lookup database as well. Another common database to migrate forward is the Footprint Lookup database, in case you have added any footprints to the database. These are common items that often get migrated forward. If you have modified your icon menus, you may also want to consider migrating them forward so any symbols you have added will appear in the new menu. You will notice under Merge/Copy Options, that most will default to Merge.Overwrite. This merges the records from the previous database(s) into the new database(s) so you will have any new data added by Autodesk, along with data you entered into the previous version of AutoCAD Electrical.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
