AutoCAD Electrical Forum
Import from Schematic List
9 REPLIES 9
Message 1 of 10
687 Views, 9 Replies
I am having an issue with a single component trying to import from a schematic list. I have verified every possible issue and concern with regard to creation of both the schematic symbol, as well as the panel symbol. No errors that I am aware of. However, when I attempt to import, I am forced to choose Footprint Choice A or Choice B. Any advice or suggestions would be greatly appreciated. Thanks
9 REPLIES 9
Message 2 of 10
ricardo_baez
Are you positive that there is an entry in the footprint_lookup.mdb that matches up with an entry in the default_cat.mdb?
Ricardo
Message 3 of 10
in reply to: ricardo_baez
Yes, I just verified again that both names are the same in both the footprint and default.mdb's. I have gone as far as to change out the footprint.mdb and found the same error. I believe now that there is an error in the default.mdb. However, all the checks that I run, do not show any issues or concerns.
Message 4 of 10
ricardo_baez
This only happens to one of your catalog entries and not others?
Ricardo
Message 5 of 10
Correct
Message 6 of 10
Correct, this is the only one
Message 7 of 10
ricardo_baez
If this is the only one, then I would not suspect a problem with either database. There may be an inconsistency in the catalog number entry or path in the footprint lookup even a block name mismatch.
Ricardo
Message 8 of 10
ricardo_baez
Can you post your blocks, catalog number and manufacturer? So that I can try to replicate this problem on my end?
Ricardo
Message 9 of 10
Thank You Ricardo,
     It ended up being a file naling issue.
Message 10 of 10
ricardo_baez
Glad to know you got it working.
Ricardo
”Boost
