AutoCAD Electrical Forum
Import connector pin descriptions
1 REPLY 1
291 Views, 1 Reply
I have been using the insert connector from list feature in autocad electrical. This feature is a real time saver but I can't find a way to auto-populate the pin descriptions. Is there a way to import connector pin descriptions (termdesc?j or termdesc?p) from an excel wirelist? The only wire I have found to edit/add pin descriptions is editting them one by one.
Thanks for you input.
1 REPLY 1
rhesusminus
As far as I know, there are no standard ways to do this in AcadE.
But API will give you some tools that you might use.
Copy/Paste this code to the command line and press enter. Then type POPULATECONNECTOR, press enter and select a connector Smiley Happy
(defun C:POPULATECONNECTOR ()
(setq en (car (entsel)))
(c:wd_modattrval en "TERMDESC01P" "LISP IS" nil)
(c:wd_modattrval en "TERMDESC01J" "FUN?" nil)
(c:wd_modattrval en "TERMDESC02P" "HOT" nil)
(c:wd_modattrval en "TERMDESC02J" "DOG" 1)
Maybe you can create some different lisp-commands for the different connector types you have?
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
”Boost
