AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
IEC to JIC
2 REPLIES 2
713 Views, 2 Replies
IEC to JIC
Hi Sirs, I am a newbee to Autocad Electrical and I am using the 2014 version. I think our company preloaded the IEC settings. I just want to know how to load the JIC settings for Schematic Icon Menu file. I tried to load the settings but I cannot find the file for JIC.
Thanks.
John
Tags (2)
2 REPLIES 2
mathalekar
Goto Control panel > Add remove > Choose autocad electrical 2014 entry.
Click on Chanage / Uninstall option
When AutoCAD Electrical Maintainance module is executed, choose  Add / remove option.
Select the standards which you want to install from options (which might be left out)
Complete the process and you shall have the seleted standards in system.
dougmcalexander
I highly recommend using the NFPA standard, instead of JIC.  JIC is a very old standard that was replaced by NFPA.  Mathlekar has already shown you how to change or add standards/libraries.  You can choose as many as you wish, but I would recommend NFPA as your standard for the U.S.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
”Boost
