AutoCAD Electrical General Discussion
New Member
jonjor3
Message 1 of 2 (2,852 Views)
IEC Symbols Electrical 2013
2852 Views, 1 Replies
09-28-2012 01:31 PM
I have the student version of 2013, after installing i dident have the IEC symbol library.
Is there a place to get a template with IEC symbols??
Employee
RobinShou-Autodesk
Message 2 of 2 (2,824 Views)
Re: IEC Symbols Electrical 2013
09-30-2012 06:15 AM in reply to: jonjor3
If you select the default installation, then the IEC symbol lib will not be installed. You can go to the control panel, select to change the AutoCAD Electrical 2013, then select Add and Remove option, then you can select the IEC symbol lib, and add it, then update the AutoCAD Electrical 2013. After the updating, you will have the IEC symbol libs.
Robin Shou
Quality Assurance
AutoCAD Electrical
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
