AutoCAD Electrical Forum
IEC Symbols Electrical 2013
2 REPLIES 2
4173 Views, 2 Replies
I have the student version of 2013, after installing i dident have the IEC symbol library.
Is there a place to get a template with IEC symbols??
2 REPLIES 2
RobinShou-Autodesk
If you select the default installation, then the IEC symbol lib will not be installed. You can go to the control panel, select to change the AutoCAD Electrical 2013, then select Add and Remove option, then you can select the IEC symbol lib, and add it, then update the AutoCAD Electrical 2013. After the updating, you will have the IEC symbol libs.
Robin Shou
Quality Assurance
AutoCAD Electrical
Autodesk, Inc.
I need Auto Cad 2013 electrical symbols.
Regards
”Boost
