AutoCAD Electrical Forum
270 Views, 1 Reply
Icon menu
How do I get the symbols for icons other than the very basic JIC electrical symbols.  Iv'e added the symbol libraries and see there are more symbols that can be used but can't use them...
What am I missing?
1 REPLY 1
lionSG
Normally, the default symbol library when you first installed is JIC, you can add more libraries(IEC,NFPA,IEE..) which I believed you already did in the Add/Uninstall Programs of ACADE.
Go check your project properties, under the project settings tab, check that the library and icon menu paths are pointing to the correct directory or folder if not, add and browse to the correct library paths for both the schematic and icon menu file.
Thanks.
”Boost
