I am having some issues when attempting to open the Icon Menu Wizard. Normally when I would click on the Icon Menu Wizard, I would have the options to select the default .dat files for either the panel or schematic icon menus. Or a third option would be to browse for the .dat file I wished to edit. For some odd reason when I opened the Icon Menu Wizard this morning, it has quit giving me the option to select the .dat file I wished to edit and just opens straight to the schematic icon menu.
Any ideas on how to fix this?
thanks,
Solved by rhesusminus. Go to Solution.
Stupid questions:
1. The window that appears. Is it named "Icon Menu Wizard" on top?
2. Have you restarted AcadE?
3. Does it work if you activate another project?
Yes, I have restarted ACADE as well as activating another project and I am still not presented with the option to select which .dat file I wish to edit. It just continues to default to the schematic icon menu wizard.
As a workaround, if you write this on the command-line:
(setq GBL_wd_sch_menu_override "MYMENU.DAT")
change MYMENU.DAT to your menu file name, and press the Icon Menu Wizard button...
That seems to work ok as a workaround although I'm not a fan of it. But thanks for the help
For my curisoity, could you turn on debugging, and run the Icon Menu Wizard command?
You can turn on "debug mode" byt typing this on the command line: (setq Aw_debug 1)
and press enter.
The run the Icon Menu Wizard again, and press "Cancel". Now, press F2 to see the command line, and copy/paste that information into a reply here...
Ok, here it is...thanks again
IN:wd_mnu_get_mnu OUT:wd_mnu_get_mnu=ace_panel_MENU.DAT Icon Menu Wizard
IN:wd_fio_does_file_exist (ace_panel_MENU.DAT) IN:wd_fio_chk_exist_usr_prj=ace_panel_MENU.DAT
wd_1a_gn_getenv WD_ACADPATHFIRST=nil OUT:wd_fio_chk_exist_usr_prj OUT:wd_fio_does_file_exist=C:\Users\jmatthews\AppData\Roaming\Autodesk\AutoCAD Electrical 2014\R19.1\enu\Support\ace_panel_MENU.DAT IN:wd_copy_file OUT:wd_copy_file=9203 Copied: C:\Users\jmatthews\AppData\Roaming\Autodesk\AutoCAD Electrical 2014\R19.1\enu\Support\ace_panel_MENU.DAT --> C:\Users\jmatthews\AppData\Roaming\Autodesk\AutoCAD Electrical 2014\R19.1\enu\Support\ace_panel_MENU.BAK
IN:wd_fio_does_file_exist (C:\Users\jmatthews\AppData\Roaming\Autodesk\AutoCAD Electrical 2014\R19.1\enu\Support\ace_panel_MENU.DAT) OUT:wd_fio_does_file_exist=C:\Users\jmatthews\AppData\Roaming\Autodesk\AutoCAD Electrical 2014\R19.1\enu\Support\ace_panel_MENU.DAT IN:wd_fio_does_file_exist (C:\Users\jmatthews\AppData\Roaming\Autodesk\AutoCAD Electrical 2014\R19.1\enu\Support\ace_panel_MENU.DAT) OUT:wd_fio_does_file_exist=C:\Users\jmatthews\AppData\Roaming\Autodesk\AutoCAD Electrical 2014\R19.1\enu\Support\ace_panel_MENU.DAT wd_1a_gn_getenv WD_USER=C:/Users/jmatthews/AppData/Roaming/Autodesk/AutoCAD Electrical 2014/R19.1/enu/Support/user/ wd_1a_gn_getenv WD_USERCKTDIR=nil wd_1a_gn_getenv WD_USER=C:/Users/jmatthews/AppData/Roaming/Autodesk/AutoCAD Electrical 2014/R19.1/enu/Support/user/ wd_1a_gn_getenv WD_USERCKTDIR=nil
I don't think i copied all of the info....here it is again...
Command: Icon Menu Wizard
IN:wd_menu_wdmenu2use OUT:wd_menu_wdmenu2use=ace_panel_MENU.DAT IN:wd_mnu_get_mnu OUT:wd_mnu_get_mnu=ace_panel_MENU.DAT Icon Menu Wizard
What happens if you type this on the command line?
(wd_mnu_get_mnu "mymenu.dat")
That just worked the same as the command you gave me earlier, which was
Strange indeed. So, no messages returned to the command line?
It's supposed to show the "select menu file"-dialog:
Do you have a networked version of AcadE with customized files?
I'll do some checking to see if I can find the DCL-file for this dialog...
This dialog is a part of the file C:\Program Files\Autodesk\AutoCAD 2014\Acade\Support\en-US\wdmnuwiz.dcl
Can you post this file here, so that I can compare it to my version?
