AutoCAD Electrical General Discussion
Active Member
jcolacino
Message 1 of 4 (304 Views)
I want to store pricing in the default_cat.mdb file
304 Views, 3 Replies
11-15-2012 11:13 AM
Good Morning, I am trying to export a project BOM to either an Excel Spreadsheet or Access Database so that I can add or modifiy a couple of pricing columns. My hope is to have Cost and Resale information stored in the catalog database so that nexttime, I can simply export the BOM and my last pricing is there. I noticed that there seemed to be USER fields in the default_cat.mdb but when I export the project "componants" to access, they do not show up. I want to keep this as simple and painless as I can...
Jim Colacino jcolacino@colacino.com
sonny3g
Message 2 of 4 (268 Views)
Re: I want to store pricing in the default_cat.mdb file
11-19-2012 06:02 AM in reply to: jcolacino
I would not recommend that you do this.  It will make your default catalog .mdb much bigger which will slow down your every day use of AutoCAD.  Especially if you are planning on having the pricing change frequently.  Better to have a seperate spreadsheet or database with the part number and pricing information.  Then create a lisp routine you can run from one of the three post process buttons available in a report to pull that information into the report when building your BOM.  Not painless or quick, but it won't slow down your every day use of ACADE.
Scott G. Sawdy
scott.sawdy@bluecoyotecad.com
testsubject
Message 3 of 4 (262 Views)
11-19-2012 07:09 AM in reply to: sonny3g
One of the ways to improve the database is to removeall the items that you will not need from the deault database and institute the use of the secondary file for the complete list.
I copied the original database and renamed it default_original and set i ti up as my secondary databse. I then removed al lthe components that I will not use from the default database. Lookups are now much faster.
Bob Hanrahan
Ace User since 1998
sonny3g
Message 4 of 4 (239 Views)
11-20-2012 01:17 PM in reply to: testsubject
We did that too.  But if we were to start trying to use the default.mdb for pricing, vendors etc, it would become very unwieldy.  As it is, we reduced it from 300+MB down to 96MB.  Sometimes smaller really is better.
Scott
Scott G. Sawdy
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
