We are moving from AutoCAD Mechanical 2014 to AutoCAD Electrical 2014 for hydraulic schematics. Once we have the schematic, we use Inventor to produce the fabrication and assembly drawings.
I have started by going through the tutorial “Pneumatic, Hydraulic and P&ID Diagrams”. The instructions seemed to be for a different version of AutoCAD Electrical. I completed the tutorial, except for the problem:
I am now trying to put one of our schematics into Electrical. Some problems that I am having are:
After layers have been established you can select the layer by entering "t" for wire type after you select insert wire command.
The "S" lines can be controlled by entering "c' (continue) while you are placing your wires. It is also important to know which direction the terminals were inserted into the symbol. If they were established in only one direction and you "flip" a symbol the wire will still try to connect in the original (left, right,top,bottom) connection direction. The "insert wire connection" tool will allow you to add a connection in the desired direction.
Ken
