AutoCAD Electrical Forum
Welcome to Autodeskā€™s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Hydraulic components in default_cat.mdb
2 REPLIES 2
354 Views, 2 Replies
I started playing with the pneumatic and hydraulic schematics--the pneumatic components have tables in the database--I have edited these in Access, but there are no hydraulic tables. I know I can create tables on the fly as I insert components, but is there a list of tables (or populated tables that I can import) for hydraulic components?
2 REPLIES 2
lionSG
One way that works for me is to add a new hydraulic component first (valve,pump,filter.....).
When you are in the edit dialog box, click on the Catalog data Lookup button.
It will triggers a message box to inform you that no such family table currently exist.
Then accept the default family name.
For hydraulic components, I think they are classified as component specific table under the family name of HY.
So when you go to the mdb file, its table structure should appear.
Thanks.
in reply to: lionSG
that's what I have been doing---it's OK since we only use a few standard components.
I was just trying to be lazy and get all of the tables at once.
ā€Boost
