Eric, if you are using AcadE 2007 you right click on the project name and
pick Properties. Under the Project Settings tab you add this path to the
Schematic Libraries. If you are using Acade 2006 then you right click on the
project name and select Symbol Libraries and add it under the Schematic
libraries section.
You can add any paths under these. They will be searched in the order
listed.
Pat Murnen
wrote in message news:5210885@discussion.autodesk.com...
When I pick an item from the icon menu for insert, it gives the error of
file not found, and list all the folders it looks into. But none of these
is the Hyd-iso125 folder. So how do I add the search path to include this
folder?
Eric
