AutoCAD Electrical Forum
how to use the values ​​section and sheet in a report BOM
2 REPLIES 2
351 Views, 2 Replies
hello
i have a project where I used to the number of sheet values "section and sheet" (see attached image)
the trouble is that I must make a equipment with nomenclature as columns tag - sheet - manufacturer - designation - qty
I know where to find this informations, but the value is not available "section" (see attached image1)
as for the sheet I must use "sect + flle"
there is there a way to add this field?
or another method?
thank you for your help
autocad electrical 2013 fr
win 7 64bit
2 REPLIES 2
JeffatSJE
It could be done but you will have to have MS Access installed, link the projects scratch database then write a lot of code to create your own reports. Short answer NO not out of the box.
thank you for the answer.
I am disappointed by this software.
I do not understand why we are not all available fields to reports as we wish
”Boost
