What should we do so that it will not place wire numbers on wires which are not required? After applying automatic wire numbering also wire numbers should not be applied.
Can we use exclude option in Project properties->wire numbers Tab-> Wire numbers option?How to use it?
Please see attached image:
I dont want wire numbers on Ground potential & I dont want to Hide them after applying.
Solved by ccad2509. Go to Solution.
go to schematics tab > edit wires/wire numbers select Creat edit wire type
go to the wire layer you are using for the ground wire layer and chnge the setting to wire numbering "no"
