Show only
Search instead for
How to suppress wire connection "dots" (or change their size)
User Question: Can the dot size be
minimised to 0 or to a very small value?
Please
advise.
Answer: The "dot" block is just a
graphical insert that lays on top of the wire intersection. It if for "looks"
only, there is no intelligence. The block name is "wddot".
To change the appearance of the dots, you would go
into your active symbol library and change the size or
appearance of drawing wddot.dwg (ex: c:/program files/autodesk/acade
2006/libs/jic125/wddot.dwg).
To totally eliminate the "dots", rename the above
library symbol so that AcadE never finds it.
Remember, for existing drawings, remove the dots
and then "purge" the drawings to eliminate the old "wddot" block
reference.
