How do you remove a deleted tag symbol reference?
Example: PB-0 was removed/deleted. New PB shows up as PB-1.
How do you fix this to when inserted it will be PB-0 again?
Solved by jalger. Go to Solution.
Hi awestfall,
There are a few methods of doing depending on how the symbol was removed.
If the Delete Key was used: (you didn't use the ACADE "Delete Component")
Rebuild the database (type "AEREBUILDDB" in the command line)
Full rebuild (since the Database thinks that PB-0 still exists) OR you could delete the project database stored in the user section
(C:\Users\<username>>\AppData\Roaming\Autodesk\AutoCAD Electrical 2014\R19.1\enu\Support\User)
If you deleted a wire number (using the delete key)
(this is usefuly for floating wire numbers or Ghosted wire numbers)
Run a Drawing Audit (the AutoCAD Electrical "DWG AUDIT" command)
(reports > Schematic > DWG AUDIT)
If the ACADE "Delete Component" was used:
Project wide update/retag
make sure you flag "Component Retag"
It will automatical restart the count.
I hope this helps,
James
Thanks, good advise. I ended up deleting the local database (based off another search) but the AEREBUILDDB sounds a little cleaner/quicker.
