AutoCAD Electrical Forum
How to pull the 10 "user" attribs on a wire num into the From/To report
10 REPLIES 10
Message 1 of 11
765 Views, 10 Replies
This has come up a couple times. I think this method will more or less work.
If you'd like to give it a try, please follow these instructions (requires
AcadE 2007 or AcadE 2008 beta or above).
1. Make backup of c:\program files\autodesk\acade 200x\support\wirefrm2.lsp
and wirefrm2.dcl
2. Copy attached modified versions of both files into the above folder.
3. Add some values to wire number attributes W01USER and W02USER like "100m"
and "600Vmax". Run the Wire From/To report and allow the report to display
in the report dialog.
4. Select the "Change Report Format" and select USER1_1 and USER2_1 to
display in the report.
5. Select "User Post". Select option 5. Hit OK.
Now look at your report dialog. Scroll down and see if the wire number
attributes you added show up in the USER1_1 and USER2_1 columns. If so,
then you're good to go. All 10 attribute values are extracted and formated
into USER1_1 through USER10_1.
10 REPLIES 10
Message 2 of 11
(reposting - having trouble uploading file)
and wirefrm2.dcl
2. Copy modified versions of both files from
http://mfgcommunity.autodesk.com/blogs/blog/7/blogpost/15278/.
This is straight AutoLisp and calls into the AutoCAD Electrical API. Take a
look at the bottom part of the wirefrm2.lsp file (you can view/edit with any
straight ASCII text editor or the VisualLISP editor). Fun stuff...!
"Nate Holt (Autodesk)" wrote in message
news:5446183@discussion.autodesk.com...
Message 3 of 11
I need it....thank you very mush......Smiley Very Happy
Message 4 of 11
I am trying to create the a MCB symbol in AutoCAD Electrical 2012,when placing it on wires after creation  ,Gap is created between the Component terminal and Wire
Please suggest the method of creation to avoid this error.
Ganesh
Message 5 of 11
randybrunette
Can you post and example of the block you created? It would be helpful to see the wire connections and where they are placed.
Randy Brunette
Brunette Technologies, LLC
randy.brunette@brutec.us
www.brutec.us
Message 6 of 11
Icemanau
More than likely, the wire termination points are not on the end of the line but spaced out a bit. This woould then create the gap you are seeing.
Another cause could be that part of the symbol is on a layer that is turned off. Check the layer dropdown for any layers that are turned off and try turning them on. If this fixes the problem, open the block and turn the layer on in there as well.
Regards Brad
Brad Coleman, Electrical Draftsman
Message 7 of 11
The downloaded files don't seem to have the same filename as those that you indicate are to be overwritten.
Is that an issue?
Message 8 of 11
eduard
Using Acade 2015, is this method still valid (lisp routine from 2007), or is another function available to get the same results in a from to report.
I cant seem to get this lisp routine to work under acade 2015
The example file represents the output i would like to get from a from/to report.
Our customers like to have connection part info, length, bundel, routing in de wiring list.
If  there is another solution to this please let me know.
Thanks in advance
Message 9 of 11
PatMurnen_Adsk
in reply to: eduard
Due to the updates made to allow user post options to be predefined in a format file, the older user post files might not work. It is the user post framework that changed and not necessarily the code for a specific option. So you can most likely take the code for an option from an older user post and plug it in to the newer one supplied with AutoCAD Electrical 2015.
I went ahead and copied the option from this older one attached to this thread originally into the 2015 one. See if the attached file works for you. You should be able to use the older .dcl file as long as the options correspond to the options within the .lsp file.
I didn't try it with the option predefined in a .set file so if that doesn't work let me know and I can look at it more closely. But, with this newer format for the user post you should be able to define the option in your format .set file and then it runs the user post option automatically before it displays the report. This also lets you use User Post options even if using Automatic Reports.
Pat Murnen
Pat Murnen
Principal Content Developer
Product Development – AutoCAD Product Line Group
Message 10 of 11
eduard
in reply to: PatMurnen_Adsk
Thanks Pat,
All works fine
Message 11 of 11
PatMurnen_Adsk
in reply to: eduard
Good. Glad that worked. -Pat
Pat Murnen
”Boost
