Solved by wan. Go to Solution.
Solved by Icemanau. Go to Solution.
The automatic spacing for multipole devices is taken from the wire spacing you specify in the Multiple Wire Bus tool.
Go to the Multiple Wire Bus tool and check the spacing there. See the attachment for what to check.
This tool is used to insert a multiple wire bus rather than drawing each wire separately.
From the sounds of it, you have not set the wire spacing so ACADE is using a default spacing which is to small for your dwg.
Regards Brad
Icemanau (NNTP handle: Brad Coleman
AutoCAD Electrical User and IT Hardware Support
