AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
[How To] Blend/Mask a part of an component
3 REPLIES 3
dk1996
680 Views, 3 Replies
I would like to know how I can blend out or mask out some parts of an component without changing the symbol in the icon library.
See attachment.
With kind regards,
dk1996
Tags (2)
3 REPLIES 3
Wheelie22
in reply to: dk1996
You can use the wipeout command, draw a polyline over the part u dont wanna see.
With DrawOrder you can change what is in front or in the back.
And than WipeOut frame off.
I always put a text there in a not printed layer, with the remark that there is a WipeOut there.
drathak
in reply to: dk1996
I was about to suggest the Wipeout command too, but I'm not sure that is what you want.  Are you trying to use one symbol to represent say two different configurations?  In your example you want the bottom part to stay, just not be visible in all cases?
If so, then yes, Wipeout will work, but it is something you would have to do every time you needed it and would have to remember that it was there. Having multiple symbols seems cleaner to me.  And with the swap block command you could easily switch between the two when the time came that you needed that bottom part.
Joe Weaver
Principle Associate Engineer - Nashville Electric Service
P&C Committee Chair – SDS Industry Consortium
dk1996
in reply to: dk1996
Thanks all, I did the following to get what I wanted.
Use WIPEOUT command, draw what you want to blend out.
To turn off borders do this:
WIPEOUT
Frame
Off
And borders are off
Do this again with Frame On so you can edit the wipeout again.
”Boost
