AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
how to add new numbers
2 REPLIES 2
189 Views, 2 Replies
Good Morning,
I'm a new Electrical user and need to ask a question.
I'm using fixed numbers and need to change the wire number after it crosses
a plug/receptacle. The program is not letting me add a new number. When I
pick "edit number" to add a new number, the previous number highlights. How
can I get around this?
Charlotte Lawrence
Sr. CAD Designer
ABX Air, Inc.
2 REPLIES 2
sven_kloeck
ACE makes a connector that has the same wire number on both sides. But you can change this.
The Electrical way: Component->Component Miscellaneous->Add/edit Internal Jumpers then select the jumpers on the right and press the delete button. Normally it should be possible now.
The simple AutoCAD way: Delete the value of the wd_jumpers attribute and all jumpers are gone.
Sven Kloeck
Electrical Network Design
There are specific symbols for terminal and connectors that force a wire
number change across them. That would save you the manual labor. The
connector builder has a toggle under details that allows you to designate
whether or not you want the wire number to change. I suggest letting AcadE
manage the wire number change on its own to avoid typos.
"Jeff Eldridge" wrote in message
news:5796842@discussion.autodesk.com...
Good Morning,
Charlotte Lawrence
Sr. CAD Designer
ABX Air, Inc.
”Boost
