I am trying to draw a swirl surface for a pencil battery>> it would more or less like this>> Could anyone show me the way.
Use Helix with z=0
Extrude or sweep surface body
Thicken to solid
Did you figure out a solution to your problem?
If not, can you attach your dwg attempt here?
I got your ans and tried to work that way.but there will be 8 layer here. measurment will be like this>>
1st layer=22um(micro metre)
2nd layer=89um
3rd=26um
4th=89um
5th=22um
6th=100um
7th=14um
8th=100um
and these 8 layer will swirl gradually and the radius will be 9.5mm. hight will be 85mm.
should i do it with scaling or how??
Did you figure this out?
You still haven't attached your dwg attempt to solve the problem?
ok brother, here is my dwg file. I was able to draw only one laye, but i need another specific layers also>>
Why can't you model the others?
I would start by creating reference circles with the beginning radius of each spiral.
From there - it should be easy.
