AutoCAD Forum
How draw swirl surface in 3d in autocad 2014??
11 REPLIES 11
Message 1 of 12
abdullah_iiuc
605 Views, 11 Replies
I am trying to draw a swirl surface for a pencil battery>> it would more or less like this>> Could anyone show me the way.
11 REPLIES 11
Message 2 of 12
JDMather
in reply to: abdullah_iiuc
Use Helix with z=0
Extrude or sweep surface body
Thicken to solid
The CADWhisperer YouTube Channel
Message 3 of 12
JDMather
Did you figure out a solution to your problem?
If not, can you attach your dwg attempt here?
Message 4 of 12
abdullah_iiuc
in reply to: JDMather
I got your ans and tried to work that way.but there will be 8 layer here. measurment will be like this>>
1st layer=22um(micro metre)
2nd layer=89um
3rd=26um
4th=89um
5th=22um
6th=100um
7th=14um
8th=100um
and these 8 layer will swirl gradually and the radius will be 9.5mm. hight will be 85mm.
should i do it with scaling or how??
Message 5 of 12
Message 6 of 12
JDMather
Did you figure this out?
You still haven't attached your dwg attempt to solve the problem?
Message 7 of 12
abdullah_iiuc
ok brother, here is my dwg file. I was able to draw only one laye, but i need another specific layers also>>
Message 8 of 12
JDMather
Why can't you model the others?
Message 9 of 12
abdullah_iiuc
I can not put the another one within fixed distance (i.e 22um)>>
my question is as i can't use offset here, how can i put one smaller helex within another at a fixed distance??I already provide the distances in my previous comment. Could you help me with drawing another layer at a fixed distance??
Message 10 of 12
JDMather
I would start by creating reference circles with the beginning radius of each spiral.
From there - it should be easy.
Message 11 of 12
abdullah_iiuc
Could you please elaborate the process or create dwg file with one/two layer??>>e.g tools name and reference etc
Message 12 of 12
abdullah_iiuc
Could you please elaborate the process more?? e.x how to create a reference circles with the beginning radius, tools name etc
”Boost
