AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
How do you represent a multi-level fused terminal in schematics?
2 REPLIES 2
ironchef31
745 Views, 2 Replies
How do you show a multi-level fused terminal block with a pass through in the bottom level in schematics?
Is it simular to a multi-level terminal block where you associate the 2 terminals together?
Ken
2 REPLIES 2
rhesusminus
in reply to: ironchef31
Hi.
Yes, I would use that technique.
Two terminals, associated together. You can always create a special symbol for the fused part of the terminal.
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
ironchef31
in reply to: rhesusminus
I tried this yesterday and it works fine. I created a new block that looks like a fuse but gave it the same attributes as a terminal.
Then associated it with a pass-through terminal for the bottom layer.
ken
”Boost
