How do you show a multi-level fused terminal block with a pass through in the bottom level in schematics?
Is it simular to a multi-level terminal block where you associate the 2 terminals together?
Ken
Solved by rhesusminus. Go to Solution.
Hi.
Yes, I would use that technique.
Two terminals, associated together. You can always create a special symbol for the fused part of the terminal.
I tried this yesterday and it works fine. I created a new block that looks like a fuse but gave it the same attributes as a terminal.
Then associated it with a pass-through terminal for the bottom layer.
ken
