Dustin
I agree with fdna49, but want to make one clarification. You probably
will want to make a copy of the drawings first (there is a tool in
Electrical to do this and also rename the drawings at the same time, COPY
PROJECT). From there you could use the export to spreadsheet command, make
the needed or desired modifications, and import the spreadsheet back in to
update the drawings.
Another option may be to use the circuitry tools. With these, you can save
out the circuits you have designed, and re-insert them in other drawings.
When they are inserted, they will automatically retag according to the
configuration you have defined for that drawing. (so basically you can
wblock out an entire drawing, insert it into another drawing and have the
devices uniquely tagged).
Then of course yet another option would be to make use of the many, many
open API calls to help automate your process as far as you would like....
Hope this helps and good luck!
Jared Bunch
Autodesk, Inc
"fdna49" wrote in message
news:242792.1103837745032.JavaMail.jive@jiveforum1.autodesk.com...
> the directions were for AutoCAD Electrical.
