I HAVE CREATED A TITLE BLOCK THAT HAS THE WD_TB ATTRIBUTE ATTACHED TO IT BUT NOW I WANT TO DELETE IT AND USE THE .WDT FILE METHOD ONLY. HOW DO I DELETE THE WD_TB ATTRIBUTE FROM MY TITLE BLOCK? I HAVE SEARCHED FORUMS AND VIDEOS BUT CANNOT FIGURE OUT HOW TO DELETE IT. PLEASE HELP! THANK YOU
Open the template drawing you used to create a new drawing, select WD_TB attribute, and delete it then save the drawing.
After that, open a drawing in the project, use swap/update block, click Option B-Update a Block and select the titleblock for updating (it works for any block, not just ACE symbols).
Click on Project, Click Do All, and click OK.
This will remove the WD_TB attribute from all your project drawings.
Do this for each project where you want to change the titleblock.
