I am not sure I understand your questions but here are my attempts at
answers -
For panel footprints, there is no naming convention that you need to follow.
You could open your existing symbols, use the black box builder and add a
few attributes and they would be ready for use. Actually no attributes are
required for panel symbols but if you use the symbols often it is quicker if
a few attributes are added to identify it as a certain type of symbol.
For the schematic diagram symbols your symbols would work for many features
with any naming convention as long as they contain certain expected
attributes. For example, a schematic parent must have a TAG1* attribute.
However, there are some features that might not work if the naming
convention described in the Help isn't followed. For example, Swap NO/NC
contact probably wouldn't work because the symbol name is used to find the
correct symbol to use.
As far as relating a schematic symbol to its panel symbol (physical
representation) the naming convention does not do this. They are related if
teh carry the same TAG value once they are inserted. Is this what you were
driving at?
Sorry if I'm not close to what you are asking
Pat Murnen
(Autodesk)
wrote in message news:4833344@discussion.autodesk.com...
Thanks for your help pat. But to use parent blocks and create a footprint
for the block doesn't work unless I have the block naming convention created
by AutoCAD E is that correct. I ask because the blocks and footprints i want
AutoCAD to relate are not electrical symbols per say there input/output
block of an amplifiers or speakers and a pictorial view of the same devices.
If you'd like some sample drawings i could do that. I appreciate the help.
thank you.
