ACE makes that task so simple by using an industry standard database format. You have two options. Click Lookup while in edit mode over any symbol. Click the Add button and start entering your new parts information in the fields provided. If you have a copy of Microsoft Access installed, you can open the default_cat.mdb database and add the data into the fields in "spreadsheet view" by opening the the appropriate table for the device (i.e. CR=control relays, LT=lights, SS=selector switch, etc.).
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
