AutoCAD Electrical Forum
How are Cables Numbered
5 REPLIES 5
petestrycharske
694 Views, 5 Replies
All,
I apologize in advance for any incoherence in my question, but I am not an AutoCAD Electrical user.  A client of mine asked me how cables are numbered and I am not completely sure how to answer that question.  From my limited knowledge of Electrical, it looks like things are sequential, but wanted to get others thoughts.  If you have any questions, please let me know.  Hope all is well and have a most blessed day!
Peace,
Pete
Just a guy on a couch...
Please give a kudos if helpful and mark as a solution if somehow I got it right.
5 REPLIES 5
As a follow up question, can someone explain to me how to add customer numbers / identifiers to cables?
Tags (2)
Hi Pete
Today in AutoCAD Electrical, cables are treated similar to components and follow the component tagging format defined.  So if the tag format is set to sequential, the cables will be tagged as such but if the component tag format is set to reference based, you will see the cables tagged in that manner based upon their reference location in the drawing.
I hope that helps!
Jared Bunch
Principal Experience Designer
Jared,
Thanks for the response!  I am extremely green at this, so I appreciate your patience.  I went to my project, right clicked and selected properties.  From there I see that there is Component and Wire Number tabs, but nothing for cables.  Does Electrical treat cables, as components or wires?  Where do I change the settings for how cables are numbered?  Also, for my own knowledge, is a cable, just a grouping of wires?  Thanks in advance for your assistance and have a most blessed night!
Peace,
Pete
@petestrycharske wrote:
Jared,
Peace,
Pete
I answered another question about how to create a cable in the following link:
http://forums.autodesk.com/t5/AutoCAD-Electrical/Wiring-Diagram-and-Connection-Diagram/td-p/3103236
I believe cables are numbered similar to a component such as a PLC, Pushbutton, etc...
drathak
in reply to: electricman1
Yes, cables follow the component naming settings.  Mostly.
However, you can always override the TAG with your customer's numbers.  It is just a manual process rather than an automatic one.
Joe Weaver
Principle Associate Engineer - Nashville Electric Service
P&C Committee Chair – SDS Industry Consortium
”Boost
