AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
hiding XREF attributes of components project-wide
2 REPLIES 2
A2u1t5o9desk
468 Views, 2 Replies
Is there a way to hide/make invisible XREF attributes of all components across a project?
2 REPLIES 2
sonny3g
in reply to: A2u1t5o9desk
Check to see if they are on a unique layer and turn that layer off.
Scott G. Sawdy
scott.sawdy@bluecoyotecad.com
Icemanau
in reply to: sonny3g
Out of the Box, ACADE uses 2 layers for the XREF attributes.
The first layer is the XREF layer and holds the XREF for the parent blocks.
Second layer is the XREFCHILD layer for child blocks.
Turn these two layers off and all the XREF data will not be displayed in that dwg.
You can also define what layers the XREF data is placed on under Layers in the dwg properties.
Check this setting if the XREF's do not vanish when you turn the XREF layers off.
There is also a command buried in the ribbon somewhere to turn the XREF on/off.
Regards Brad
Brad Coleman, Electrical Draftsman
”Boost
