I'm currently working on my panel layout and inserting componants but why will the componants not hide the din rail? I've read on using the "wipeout" tool but that doesn't seem right, not to mention extra work. Also when looking at the example drawings (DEMO09.DWG) I see that if you relocate a componant off the rail it "unhides" itself and vise versa. Please help this noobie......
Your panel symbols(blocks) should contain a wipeout entity that hides the dinrail. If you explode one of the terminals in the demo9 drawing you will see that it contains a wipeout. Also, sometimes it's necessary to send the dinrail to the background in the draw order command.
David
Wipeout is the correct method. Open the footprint symbol block file and trace around the perimiter of it with Wipeout. Next, send the wipeout region to the back. Save the block. Now when you insert it over DIN rail, it will hide the DIN rail. If it doesn't hide, click Home>Modify>DrawOrder>Send to Back and send the DIN rail to the back.
