AutoCAD Electrical Forum
Hidden Attributes
2 REPLIES 2
sdbell
1443 Views, 2 Replies
Hidden Attributes
When i Insert a component some of the available attributes are hidden by default. Could someone tell me if this is symbol specific and if i can alter the default to show certain attributes at the point of insert instead of going through the motions of right click unhide etc.
kind regards
Shaun
2 REPLIES 2
dougmcalexander
in reply to: sdbell
Just edit the block and use the properties tool to set the desired attributes to Invisible = No. You may need to scroll down to see the parameter called "Invisible" as it is near the bottom of the properties window. I've done this with MFG and CAT when I anted them to default as visible. You have to increase the text size as well with MFG and CAT, but just about anything you desire is possible.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
sdbell
in reply to: sdbell
Thanks for the reply.
Could you tell me where all the blocks are so i can browse for them before inserting?
regards
Shaun
”Boost
