Hi
I'm using Autocad Electrical 2013.
I want to add a AB 1769-IF4 CompactLogix PLC input card. It's a 4 channel Analog (current and voltage) input card. I'm not programming it, but if i recall, the IF4 can be channel set so that Ch1 is Voltage, 2,3 is Current and 4 is Voltage.
When I go to the PLC Parameteric Button i can only put in a Voltage version or a Current version. Is there a way to Mix/Match w/o having to create a specific instance (out of the 16 total compbinations possible) ?
Try to use PLC Database editor to copy the existing 1769-IF4 and create a new mixed module and change the necessary inputs to current and voltage type that you want. Think its faster this way.
Try this site, see if its can help you to generate flexible AB IV type input anot.
