AutoCAD Electrical Forum
Help to change wire type property project wide.
1 REPLY 1
561 Views, 1 Reply
ACE 2010 user
I have been using the (ace_add_wiretype "JUMPER") within a script to setup wire layers in an existing project. Is there another command or switch that will set the 'Wire numbering' to 'no' for layer JUMPER?
Thanks in advance.
1 REPLY 1
Have been able to work it out for myself, adn no it isn't documented anywhere.... For future reference to anyone with this issue add the following to set wire numbering to 'No'.
(ace_add_wiretype "JUMPER" "WIRE NUMBERING" "NO")
”Boost
